โJul-17-2019 02:34 PM
โJul-18-2019 04:14 AM
joebedford wrote:Some devices can use either type of cable. It's possible that the 3 10ft cables he tried are crossover cables and had never used them connected to his laptop before.
He said it used to work so I seriously doubt it's a miswired connector.
โJul-17-2019 07:42 PM
DFord wrote:He said it used to work so I seriously doubt it's a miswired connector.
Put the ends of the two cables together side by side to see if they're both made the same way.
โJul-17-2019 07:33 PM
โJul-17-2019 06:11 PM
TenOC wrote:GordonThree wrote:
Bummer, likely the port on the laptop is damaged.
Then why does it work with a 6 foot cable?
โJul-17-2019 05:07 PM
โJul-17-2019 04:38 PM
โJul-17-2019 04:02 PM
GordonThree wrote:
Sounds like the ethernet port is damaged on one or both ends.
On the side of the 5 port hub, switch the connections being used by the laptop and printer.
โJul-17-2019 03:00 PM
โJul-17-2019 02:45 PM
