TenOC
Jan 04, 2017Nomad
3Tb Hard Drive Problem -- Win 7 ???
I have a problem. I have searched Google but could not find an answer. So I ask my RV computer experts.
I have a HP xw8600 with Intel Zeon X5260 @ 3.33 Ghz desktop. I have an Hitachi HDS53030ALA630 3Tb hard drive that I use for backup using Symantec System Recovery 2013 R2. The HD is format GPT - NTFS. Window 7 Ultra 64 disk manager reports this as a single 2,794.53 Gb Primary partition. The disk appears to work OK.
However when the backup data stored exceeds the 2.2Tb limit all type of problems happen. The hard drive appears to loose its GPT status and check disk reports a large number of errors. Thus I lose my backups. The same problems happen it I simply copy more than 2.2Tb of date to the HD.
If I use the HD in a Plugable external hard drive docking station that is design to accept up to 4Tb drives , the HD appears to work OK without the 2.2Tb limit. Thus I think the HD is good.
Questions.
1. Could the problem be my motherboard does not support the 3Tb drive?
2. If I partition the drive as a 2Tb and a 1Tb will it work? In other words, is the 2.2TB limit for a partition or for the total drive?
Questions.
