acker1's avatar
acker1
A/B Switch?
What kind (make/model) switch to be able to pass the signal from either my rooftop dish or tripod? Tired of pulling the receiver to change cables whenever I get in trees. I think it has to be able to send voltage to the dish as well as receive signals.
Thanks
DICK
  • A push button A/B switch is the better choice but I also have slide switches that work fine. They are not always easy to find - start at Radio Shack.
  • I use a splitter with a slider switch. They say Cable/Antenna. Use them with success at home and on the RV. Available lots of places, got mine at Lowes.
  • I used two coax A/B switches from Radio Shack for this exact purpose on my Directv DVR and it works great.
    Thanks
    DICK
    If you are using Coax, then any simple A/B switch found at Radio Shack or electronics section of Walmart will work. If you are using a DVR that has two inputs, you'd need one A/B switch for EACH of the two lines. For example, you put the leads coming from the tripod into A of EACH box and then the two from the Roof Top into B. then on the 'out put' from the A/B box run a single short coax from EACH into the back of your DVR. If you are using HDMI cables, then they also make 'multi switches' for the HDMI cables.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
