- Dutch_12078Explorer III
Ralph Cramden wrote:
wa8yxm wrote:
Sat 117 is one of the Dish Birds as I recall so anywher you can get Dish Western Arc it should work..
Dish uses 110,119,and 129 for WA and 62.5,72.7, 77 for EA. 117 is not an Echostar sat.
John is probably thinking of the 118 sat that Dish uses for their International package. - 2oldmanExplorer II
You mean Orby?
My cheap Brother in law recently had ORLY installed,. - Ralph_CramdenExplorer II
Page 2: It's till too much to pay as far as I'm concerend. I do OTA for 25/year (Cost of electronic TV guide) If I wanted to MANUALLY program all recordings I could skip the 25/yr.
Dish uses 110,119,and 129 for WA and 62.5,72.7, 77 for EA. 117 is not an Echostar sat. Using multiple birds, if an issue crops up they can switch programming to a different transponder or even a different bird. Direct uses multiple birds also. With this Orly who knows what can be done if they lose a transponder or something.
My cheap Brother in law recently had ORLY installed, he is always the first to jump into the crappile spending dollars to save nickels. The local antenna they installed only picks up FOX out of Pittsburgh. We're both about 35 miles as the crow flies from the city. As a comparison I can get all 4 networks over the air using the batwing on the trailer in my driveway, and he is a good 400' higher in elevation and only gets Fox 53. He said the Orly installer told him to get a rotating mast to mount the OTA antenna on and that "might" work. Reminds me of my dad turning a dial while kicking the TV back in the 60s while spewing profanities. - wa8yxmExplorer IIISat 117 is one of the Dish Birds as I recall so anywher you can get Dish Western Arc it should work..
Page 2: It's till too much to pay as far as I'm concerend. I do OTA for 25/year (Cost of electronic TV guide) If I wanted to MANUALLY program all recordings I could skip the 25/yr. - GordonThreeExplorer27 8nches by 18 inches dish plus one or more OTA antennas no thanks.
- LynnmorExplorer IISince Dish uses 119 & 129, I would think that 117 would not be a big issue. I often cannot get the 129 bird, but still can get my favorite channel which is Fox news.
- Bill_SatelliteExplorer IIThe dish is not that big at 27"W and 18"H. A little bigger than a DTV antenna. Not having FOX News is the #1 reason I might switch!
It uses 1 satellite at 117W and would be no harder to point than any other DISH/DirecTV antenna on a proper tripod.
There is NO Network programming. Period. All local programming is provided by an OTA antenna that is installed separately from the satellite antenna.
Not all of the channels are available in HD but it seems a bit difficult to determine which are which.
This is a very Western located satellite so pointing may be difficult in the NE or SE or any Eastern areas with a lot of trees.
The up front costs are pretty high since you have to buy the receivers ($200 for a 2 tuner DVR) $4/month for the DVR service is pretty cheap. However, the savings for multiple receivers (if you use 2 receivers) is about $7/month.
This seems like a service living in the past as it only has 2 transponders on the 117W (116.8) satellite so what they can provide is quite limited. - valhalla360NavigatorCheap cellular data is killing off cable & satellite...it will take some time but it's a dying industry.
- 23mikeyExplorerLooks to be a solution for a fixed location. Equipment wouldn’t be RV friendly.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
