I'm not sure where to post this as it involves the antenna in our vehicle. We've had a problem with the radio for a while and have finally traced it to a loose connection behind the panel behind our '...
The car is a 2006 Mazda 6, and the antenna is in three sections with two connections, one in the C pillar and the other down by the drivers footwell. I had thought that the problem was just the connector not making good contact , but I see now that it's probably a loose connection in one of the ends, probably the male one. Of course the antenna is working now , but the next time it goes, I'll have to pull it apart and see if I can re solder it! Thanks for all your help.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
