time2roll
Oct 24, 2015Nomad
I have and recommend 300w GoPower sine wave inverter.
I connected mine behind the electric panel. 12v supplied by the main battery connection. Add a small transfer switch to connect to the single 120v circuit needed for tv & satellite. All built in and automatic.
Yes I recommend you have minimum two batteries and change the most used lighting to LED to save additional power.
If you do this a lot and mostly park in the sun consider 100 to 300 watts of solar.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
