- Home_SkilletExplorer IIYou can, if the connectors match.
I doubt it though. - GdlowExplorer
Home Skillet wrote:
It is pretty much plug and play.
You'll have to hook up a ground and power wire.
The hardest part is running the wire from the front of the RV to the rear.
I guess that is my question. If a MH already has a camera and monitor, can you use existing wires? ,etc. - Home_SkilletExplorer IIIt is pretty much plug and play.
The hardest part is running the wire from the front of the RV to the rear. - GdlowExplorerHow much tech knowledge is required to change out the camera? is is somewhat of a punplug plugin kind of thing...:h
Supercharged wrote:
Home Skillet wrote:
Looks good, I'm going to buy one to, mine works as well as Obama care.
Blue screen is a loss of signal from the camera.
You may have a bad camera or a cut wire to the camera.
I just installed this on my RV. Very high quality and Hi def pic.
Reverse Camera
I had the back up camera from rvcams.com. It started showing fuzzy and had several vertical lines on the screen. It never did show that great anyway. In the trash, that went. - KansasRVExplorerRear View Safety is actually less expensive than Tadi when you add normal components you would use anyway.
http://www.rearviewsafety.com/safety-solutions/backup-camera-systems.html
With most brands you can use adapters if you just want to replace the camera. - GulfcoastExplorerMy Rear view safety uses coax cable with metal screw connectors and looks like the Tadi use phono-type plugs with cheaper cables.
- HudsonerExplorerI just got a new setup. I compared Rear View Safety and Tadi Bros. Tadi Bros are lower in price and work with you to get the right system.
It might be possible to just replace the camera.
http://www.tadibrothers.com/category/backup-camera-kits?gclid=CIK3063FkM8CFQx9fgodIZwAYw - SuperchargedExplorer
Reverse Camera - GulfcoastExplorerThat's the camera setup I have also. I am very pleased with it. The picture is so clear.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
