- donn0128Explorer IISure.
- RLS7201Explorer IIGet a Buck transformer off of e-bay to protect your blu-ray player.
Richard - joebedfordNomad III thought Bucks are only for AC applications??
- Clay_LExplorerMaybe. Depends on the DVD power input circuit. If it designed to take more than 12 volts it should be okay. It costs a little to make the power input tolerant of higher voltages and who knows what they did.
- 1492ModeratorWhat DC voltage (metered) is the wall wart actually outputing?
- RVhikerExplorerI've got two meters. The ancient Micronta digital (I bought it way before I got grey hair) says 12.51 volts. The newer Craftsman meter says 12.3. Both under no load, of course.
- MrWizardModerator
its a DC buck power supply, its a circuit board with components to regulate the voltage to 'your' set point
most are adjustable over a wide range, like 12v-40v in
and 5v-30v out
there are BUCK only
Boost only,
and buck/boost, which can do both functions
say power fluctuates 10v-15v and you want to maintain 12v
then use a buck/boost module
Drock is one brand, well know, good quality,
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
