Rbertalotto's avatar
Rbertalotto
BlueTooth repeater / booster ???
Now that I have a WeBoost in my trailer, and it works fantastic, I need to leave my phone on top of the "Hersey Bar" antenna and I walk around with a BlueTooth earpiece. But the range oif the BT earpiece is limited to about 50' and I like to wander/pace as I talk to clients.
Are there BT boosters like we have for WiFi and Cellular?
And advise is appriciated
  • How about this product? I sent an email with my specific use in mind...
    https://aircable.co/
    AIRcable Long Range
    Our Long Range Products
    AIRcable's individually calibrated full power Bluetooth radios are many times more sensitive than the average Bluetooth device. That is the reason why you can expect over 10 times more range than with other standard Bluetooth dongles.
    Extend the range of your PC to Bluetooth devices with the Host XR. These products plug into the USB port and work with Windows, OSX and Linux. They provide a standard bluetooth interface and require no extra drivers. Use it for connecting Bluetooth keyboards/mice, headsets for Skype, stereo audio connections and more.
    Using two of our long range products together with the biggest directional antenna we have certified with the FCC, you can achieve 10km range. Given you are above the Fresnel Zone.
  • Base to handset is 1.9ghz dect, base to cell is 2.4ghz BT.
    A simple wired headset will plug into the cordless handset. A fancier model might support a Bluetooth headset from the handset, I don't know.
  • FANTASTIC! Now why didn't I think of this! Thanks for a great idea!
    If I want to use a handsfree earpiece, I'll need to find one that works with this phone, and have the phone with me as I 'pace"....correct?
    If I understand it correctly....the handset talks to the base via 2.4mHz and the base connects to the cell phone via BlueTooth.....So the handset needs to travel with you as you wander.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 15, 2026
