โMar-17-2020 11:43 AM
โDec-20-2020 07:25 AM
โDec-19-2020 08:31 PM
โDec-19-2020 06:25 PM
โDec-19-2020 05:09 PM
โDec-19-2020 02:18 PM
โDec-19-2020 02:06 PM
โDec-19-2020 10:05 AM
โDec-19-2020 02:26 AM
โDec-18-2020 04:29 PM
โDec-18-2020 05:59 AM
Cloud Dancer wrote:
I have Direct TV satellite and Spectrum ground cable. I replaced the bedroom 32 inch Samsung with a 40 inch Vizio, from Best Buy. It has 4 HDMI ports and ONE port for regular co-ax cable connector. I connect Spectrum using HDMI port and Direct using co-ax cable.
I could not make this new TV show anything on Direct TV, except NO SIGNAL. I went back and explained the problem to Best Buy. They said it would cost me $100 if they sent out a Geek techie,...OR I could have another 40 inch Vizio, in the new sealed box.
I connected the new one, with same results! I tried it with my two other Direct TV receivers, with same results. I replaced the co-ax cables, with same results,...NO SIGNAL. I connected, one by one, ALL my other TVs, total of five. They all receive Direct TV just fine.
Is this model Vizio simply not compatible with Direct TV signal?
โMar-19-2020 07:56 PM
Bill.Satellite wrote:
Unfortunately, even if you get an HD receiver which is capable of High Def, if you are using a dome, the dome can only receive SD programming and the picture will be small and it will be cr@ppy. However, it will be a more simple setup as you just select the appropriate HDMI input. That will also allow you to connect your existing OTA TV antenna to that one coax connection, do a new channel scan and you will be able to watch all of your favorite local TV channels in FULL HD! The OTA TV is the VERY BEST TV viewing available as it is not compressed like the other options. Want to watch the Super Bowl and you have Cable or DTV or DISH? Switch to the OTA antenna for a substantially better picture!
If I read you last post correctly there appeared to be a complement in there. If so, many thanks!
โMar-19-2020 07:23 PM
2oldman wrote:
I hope you weren't looking for 'tunners' ๐
Glad you're making progress, but that TV really deserves a new HD receiver!!
โMar-19-2020 04:34 PM
โMar-19-2020 04:22 PM
