mgpassport's avatar
mgpassport
Camp stove
Marcus....
I have a Passport 145EXP, It has an outside auxiliary connection for a propane hookup....
I was told by the dealer that I could not use a coleman stove because I would then have two regulators in line and that would not work....
So what stove do I use..?..I searched and could not find what I thought I needed....
Thank you in advance for any info....
Mike G
  • I'm thinking you will need a "RV-Q" grill. I had a connection for mine as well. It had a little label over it that stated RV-Q. They use a different PSI than regular grill, and stoves
    I also had a valve that had to ne opened before the connection would work.
  • Go to a propane supply company & have the hose made up to suit your needs with the appropriate fittings on each end.
    Assuming your Coleman stove uses the 16oz bottles, it has a built in regulator where the bottle attaches. You need to connect directly to stove without that connection.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
