2oldman's avatar
2oldman
Jul 19, 2019
CC vector wifi antenna
I'm using this wifi booster right now and it works great, but I'm baffled on something.
On initial setup, you log in, then open your browser and a page comes up and shows you the available wifi networks to be boosted, and you choose one. That worked fine, but then I decided to turn the antenna 180 degrees and now I cannot get that screen to come up. I've unplugged everything, waited, tried the 192.168.8.1 thing which they show in the manual, but nothing.
Youtube etal says to go 192.168.18.1 but Chrome says no, can't connect.
Anybody know what to do?
  • wa8yxm's avatar
    wa8yxm
    Glad it worked.. I've been doing Wi-Fi with assorted hardware for a long time. Some of the ways it can screw up will drive you batty and then some.
    I use both static and dynamic addressing and a home made wi-fi repeater (Umbiquiti Nano Station outdoor and a pain in the arse Belkin indoors)
    I have multiple computers (ReplyTV dvr. Windows Chrome books and two (realy 3 but one is still in the box) Raspgerry Pi's running ham radio software so I am learning ALL the shortcuts to success.
    Glad that one worked for you.
    One thing.. Many places you log onto a public router and they may not even change the SSID (LInksys is a common one) I've accessed more than one config page on such a router.
  • wa8yxm wrote:
    Alternative look at your computer' wi-fi settings (Advanced) for the gateway addres.. try to connect to that address.
    That worked!! Thank you !!
    I bookmarked that page (as the instructions tell you to do) when it came up so I should be able to access it anytime.
    Yay!
  • I was considering hacking the registry but can't seem to do that on a chromebook. Support is closed for the weekend.
    If power cycle means 'turn it off' that's what I did.
    The config screen actually did come up once yesterday.. I have no idea what I did.
  • wa8yxm's avatar
    wa8yxm
    You may need to do a power cycle.
    Soemtime I've found devices like that, when they connect to a Wi-FI Access point or router will change their LAN SIDE address and you need to power cycel them
  • some of these repeater systems change ip addresses once they connect to a access point.
    there should be a reset button to hold in a few seconds to reset it.
    one of the ones i have has a tool to download to find the ip address it changed to.
  • It will show the screen even if no wifi is available. It's turned back. I tested this at home, did pretty much the same thing and didn't have this problem. I'll probably have to call CC in the morning.
    Hmm.. I'm using a Chromebook. At home I used an HP laptop. I wonder if the CB is different.. needs some config setup. I did clear Chrome's cache.
  • it's a directional antenna. maybe it's not detecting any wifi stations in that direction? have you turned it back in the original direction?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
