- Bill_SatelliteExplorer IITV Antenna Helper will let you use the current location, download the channels that you can receive in the area with strong, medium and unusable signal.
It shows the local channel designation plus the RF broadcast channel. So here in Orlando, CW18 is 17. CBS6 is 26. ABC27 is 27. ABC9 is 39. Fox35 is 22.
Good info at the touch of a button. - jcpainterExplorer
wa8yxm wrote:
There are three ways to convert the displayed channel to the carrier channal (which is what the Sensar Pro shows) and possibly even the frequency depending on the programmers.
1: Internet. You can get a list of what channels use what carriers (The number on teh Sensar is the carrier) from assorted sources
2: Apps like Antenna Helper (Free) on my Phone do it. but it may take a bit of searching to figure it out
And the easiest way
Go to the television, once it has "Scanned" go to set up. channels. manual add
now if you are tuned to a channel. Most TVs will show you, when you enter that page
A "Thumbnail" of what is airing, the channel (Display) and the carrier channel (Sometimes even the frequency)
WRITE IT DOWN and keep a spread sheet
The sensar in SCAN mode will display the strongest carrier. You can then go down the list... I keep a list of what channel to aim for in each park I visit
The part that's missing from this is to have the antenna pointed in the direction of the main channels you want to receive, before doing the scan. The apps are useful to show you the location of the broadcasting channels so you can correctly position the antenna for the best results. - wa8yxmExplorer IIIThere are three ways to convert the displayed channel to the carrier channal (which is what the Sensar Pro shows) and possibly even the frequency depending on the programmers.
And the easiest way
The sensar in SCAN mode will display the strongest carrier. You can then go down the list... I keep a list of what channel to aim for in each park I visit - jcpainterExplorer
wildtoad wrote:
There is a smartphone app "TV Towers" that you can use not only to see where the local towers are but also get the numbers you need. I know it has an iPhone version not sure about others.
Thank you! That's exactly what I was looking for: simple, easy to use. - wildtoadExplorer IIThere is a smartphone app "TV Towers" that you can use not only to see where the local towers are but also get the numbers you need. I know it has an iPhone version not sure about others.
- Tom_M1ExplorerUnless your Sensar Pro is different than mine, you don't need the channel frequency. You need the RF channel number. If you go to the site I referenced, you will be able to get a list of nearby TV stations. The first column in the table is TV Ch which is the digital virtual channel. The second column is RF Ch which is the real channel.
- Tom_M1Explorer
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
