esyers's avatar
esyers
Convert xlsx to xls file
Hi,
I have Excel 2002. I now need to open a .xlsx file. I've downloaded and run the "FileFormatConverter" file from Microsoft, but still cannot open the file. I'm using Windows 7. Any suggestions? Thanks
  • You need to take sch911's advice and install the Compatibility Pack so that your Office 2002 will open the newer files. It's free!!!
  • I knew you guys would be fast with the answer, but I never expected THIS fast. The Viewer and Open Office both do the trick. Thank you all very much.
    As far as having the originator save it in xls format, I had thought of that, but explaining to him how to do it was going to be a major challenge.
    Thank you all once again
  • Not familiar with the conversion program.
    Is there any reason you cannot have the file creator open the original and resave in the .xls format?
    Is there someone with the newer Excel version who you can send the file to and return is to you in the .xls format?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 15, 2026
