teeznu's avatar
teeznu
Dell Laptop Touch pad issue
The computer is a Dell Laptop Inspiron 15 3000 series. Of late, the touch pad (ie. mouse) has been acting up. To describe the issue when you put your finger on the touch pad and move it around, the mouse pointer reacts as normal. But when you go the the "Scroll down vertical bar" on the right hand side of the screen, take your left hand pointer finger and press on the lower left corner of the touch pad, HOLD IT DOWN and then take your right hand (pointer finger) and try to move the scroll down bar "DOWN" nothing happens. Sometimes I "lick" my pointer finger and it makes the scroll down bar move. Other times when I go to scroll "Down" i.e. pulling the bar down, nothing happens. BUT, when I move the scroll down bar in an upward motion (on the touch pad) the scroll down bar will move down. Additionally, the "Cut and Paste" feature when you want to "Highlight" a word or phrase, copy it and then past it somewhere else, this feature is TOTALLY GONE. NO-FUCTIONAL. I've been to "Settings" "touchpad" and adjusted the sensitivity but that hasn't helped the issue. Can I just have the computer have a new touch pad installed? OR, what are your thoughts?
All comments are appreciated in advance.
  • I have found doing a PC restart solves many problems including mouse pointer issues. Try it you might like it says Mikey.
  • wa8yxm wrote:
    My opinion of those touch pads is not something I can post (Language involved(
    Turn it off and use a wireless mouse.
    WA8YXM,
    That may be an answer to you, but I am usually navigating for my XYL and using a mouse in a moving vehicle is a lost cause. A track ball is better, but the touch pad is the way to go. The built in touch pad also goes with you when you pack up the laptop to travel.
    Matt
  • wa8yxm's avatar
    wa8yxm
    Kinky! GRIN...............
    Richard
  • When my Dell laptop started acting up, the problem was a swollen battery. The battery lies beneath the touchpad and can cause it to behave wonky.
    Rub you fingers lightly over the touchpad and feel if it is completely flat. If you feel any degree of it being raised, you probably need to replace the battery.
  • Have you checked for updated drivers?
    I use a separate Logitech wireless mouse.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 06, 2025
