Oct-28-2018 12:04 PM
Oct-29-2018 07:51 AM
Oct-28-2018 03:09 PM
Oct-28-2018 03:06 PM
hpdrver wrote:
I completed the swm 8 installation on my Winegard T4 dome diish. I have my hr5400 receiver hooked to the Power Inserter and the Power Inserter connected to the swm1 position. I have my h24 receiver connected to the swm2 postion.
I turned everything on and set the h24 receiver to 18” round and swm and it worked fine and received all channels and accessed my recordings on the hr5400. However when I tried to set the hr5400 receiver to 18” round, it wouldn’t allow me to do this. It only gave me a choice of 3lnb or 5lnb. Has anyone had this problem and how did you correct it.
I believe my swm8 installation is correct and if I can set the hr5400 receiver correctly, my problem will be solved. Thanks
Oct-28-2018 03:01 PM
Big Katuna wrote:
I’m pretty sure the sat box will work without the PI. It’s the LNB that needs the PI.
2oldman wrote:
Afaik there is no dome dish that works for DTV HD...unless you only want SD, and then there'd be no reason for Swm.
Oct-28-2018 01:42 PM
Oct-28-2018 12:56 PM
Oct-28-2018 12:17 PM
