Big_Katuna
Jan 22, 2017Explorer II
The newer SWM onLy has one output that goes to a splitter which also connects the power insert er. It is most likely inside his RV.
You could connect there but that means running a cable thru a window.
If there are four connections at the LNB then you could.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
