georgem2106's avatar
georgem2106
Dish Pro Premium
Has anyone bought the new Pro Premium tailgater? If so, your thoughts. I see it comes with only 50' of RGB. Especially interested to know if it has the limitation of being only 50' from the receiver?
  • If you want full eastern arc coverage, something I do suggest for the best aiming opportunities, take a look at the Winegard Pathway X2.
  • Lynnmor wrote:
    The quality of the cable has much to do with signal loss over distance.
    I believe that the Pro does both eastern and western satellites, is that the reason for buying that model?
    The Pro only uses the eastern arc 61.5 sat. It still uses the western arc 110 and 119 sats for other programming.
  • Quality and length of cable is also important in providing power.
  • Don't know if it is a typo or not but the description shows "using Western and Eastern satellites (110/119/129 or 110/119/61.5)". I always thought it was 110/119/129 and 61.5/72/77. However, I fooled with the original Tailgater more than a year too long before realizing it was only worth being a door stop unless one was in an open field or parking lot. I understand the Pro is more versatile. Been using the Pathway X2 for several years and even in Canada, 4 hours North of the border in the middle of forested nowhere I get decent reception running as much as 150' of good cable when needed.
  • The quality of the cable has much to do with signal loss over distance.
  • Yes, that is about it. Once you get it set up and a good signal, you could try a longer section of coax, and check if you still have the same signal. In my limited experience, it has more to do with the connections than length. I carry a 35' length, and a 50' length both. Have tried connecting them with poor results.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
