Rbertalotto's avatar
Rbertalotto
Easy Outside USB jacks...
I wanted to be able to charge my devices while I'm sitting outside under the awning. The easiest method was with this device.
TOPGREENER TU21548A 4.8A Duplex USB Charger Outlet
Simply replaced my duplex with this device...Done!
Upgraded High Speed Charging Tech: World's First Smart Ultra-High Speed Dual USB Charging In Wall at 4.8 Amp, 24W, 5VDC
Charging-Smart Technology: Dual "Smart" USB Ports Precisely "Read" the Power Need then Maximize Charging Efficiency
Design Innovation: Interchangeable Face Cover. 3 Color Face Cover Included: White, Black, Light Almond
Two TR Tamper-Resistant Outlets enhance electrical safety, preventing the attempting to insert objects into the outlet; Meets 2011 NEC
Compatibility USB 1.1/2.0/3.0 devices, 2 USB ports total 4.8 Amp, 5VDC; Two TR Receptacles 15 Amp/125VAC; UL lsted; 2 years warranty; Back & side wiring easy installation. Wall plate not included
About $20 on amazon
http://www.amazon.com/TOPGREENER-TU21548A-Resistant-Receptacle-Interchangeable/dp/B01BTC5I5O?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
  • I had a TopGreener in the house that, after about 3 months, the USB ports just stopped working. IIRC others had that issue too. I just swapped it out, today, for another brand that I found at Home Depot. I'm hoping the other brand lasts longer.
    Be gentle with it and maybe it'll last longer than mine did.
  • RoyB:
    Electrical insulation. All my RV outlets, including the outdoor on clamp onto the wires in a parallel arrangement. There are no bare wires or exposed terminals.
    Only an extra outlet and wiring I added have bare wires wrapped around exposed terminals. This outlet I put in a surface mount wall box.
  • Very nice but here is one that will work on 12 volt power. 12 volt
    That is a nice, clean , way to mount 12V receptacles. Thanks for the lead!
    I used a bunch of these throughout the camper.
    But the one you posted would fit nicely in an outside weather box.
  • Is it insulation displacing like typical RV receptacles?
    If you mean wall insulation.....This is a typical , poorly built, RV...There was zero insulation in this wall cavity. I used an inspection mirror to see if there was any up or down...Nope!
    This was a wall cavity where lots of wires were run and I guess they just thought it wan't needed.
    And you should have seen how the hole was cut in the side of the trailer for the receptacle. Only one screw out of four hit anything. It was basically held on with the Dicor sealant!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
