- bojo2112jonExplorer***Link Removed***
- RandyWattsExplorerThanks for sharing, very informative!
- sonnywExplorerThere is a skilll for Alexa show....My Radar NOAA Weather Radar. Search for it in skills
- wa8yxmExplorer III
MrWizard wrote:
that link doesn't work
try this and click a blue dot
https://radar.weather.gov/ridge/
I do that one every day. Then using the links on the left I can go to the local area and either static or looped
Learned a lot about reading Weather Radar after years of looking at the map and then out the window. - MrWizardModeratorI gave my wife an echo show "8" for Xmas
It has web browser browsing built In
No longer need to create an special skill - flexomobExplorerI still don't understand why you think that without programming there are only some restrictions on templates. Not always there are some restrictions, much also depends on skills and it isn't necessarily programming
- bwanshoomExplorer
ccchuck wrote:
Without programming, you're limited to what's provided by the Skill Blueprints and it doesn't look like they have much functionality. You pick a template and fill in the blanks, basically. So like a quiz show where you provide the questions and answers or a story teller where you provide the story.
Would you guess if a skill to show a webpage is possible? I have no background in programing, so I'm at the mercy of whatever gets posted by DIY types. Would appreciate a heads up should you see something that might work for me.
Even if you can program, displaying a webpage is probably going to be a challenge in any case. The Show's display capabilities are limited to some predefined templates, as far as I know. In theory, you could probably create an image of what the website display looks like, but I think it would be a lot of effort. - ccchuckExplorer
bwanshoom wrote:
I've written a couple. It's definitely non-trivial - if you don't have a development/IT background it can be a challenge. It supports any web language and their are frameworks already created for many of them such as Python and Javascript.
However, Amazon recently announced a much easier way to create skills called "Blueprints". I have not looked into this yet, but it seems oriented to pretty basic ask/answer kind of skills.
You need to have a web endpoint to handle the requests, the things the user will ask for. That means running a public web server which is probably beyond casual skill creators. An alternative is to use AWS Lambda.
Would you guess if a skill to show a webpage is possible? I have no background in programing, so I'm at the mercy of whatever gets posted by DIY types. Would appreciate a heads up should you see something that might work for me. - bwanshoomExplorerI've written a couple. It's definitely non-trivial - if you don't have a development/IT background it can be a challenge. It supports any web language and their are frameworks already created for many of them such as Python and Javascript.
You need to have a web endpoint to handle the requests, the things the user will ask for. That means running a public web server which is probably beyond casual skill creators. An alternative is to use AWS Lambda. - MrWizardModeratori took a quick glance at the tutorial site
the writing AKA 'programing' uses Python
Python is a scripting language i dabbled in a little bit about 6 or 7 years ago
and nothing since then
you have to think in logical progressive steps (like almost all programing)
its not like writing a recipe or directions
i did not dig deep, into the 'skills' writing
but seems more oriented toward controlling home functions, lights etc, via echo controlled modules and fetching info stored for alexa, dates, appointments, music from amazon
than grabbing random webpage data you might want to see
like i said i did not dig deep, and might have the wrong perception
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
