armadillo_17's avatar
armadillo_17
get satellite signal in
Has anyone used the cable in coach for their satellite coax, by bypassing the booster? Is there some sort of switch that would allow cable use or satellite ? Thanks
This business of running the satellite coax out the window, not the best.
  • There are several ways to do it. In past years Winegard recommended the diagram below.
    Making the connections the way Winegard recommends does not require adding any coax connectors to the wall plate.
    Note that this assumes your front TV is connected to the coax connector on the front of the wall plate. If yours isn't, there should be a splitter in the line labeled "To second TV" that will send the signal to both the front and rear TVs (if you have two TVs).
    What Winegard calls a "power supply" below is the wall plate with the antenna booster switch and LED showing when the amplifier is on.
    If you still want to be able to use the external cable in for both cable TV and the external dish just add an A/B switch to switch the incoming coax from the sat receiver "sat input" to the sat receiver "TV input".
    If your receiver doesn't have a coax output (and most new ones don't) and you still want to use the batwing antenna you will need to use an A/B switch to switch the signal between the receiver and the antenna out connection on the wall plate.
    One thing not shown in the diagram is using the RCA type connections or the better quality "component" type output or the HDMI (best) output between the sat receiver and the TV.
    That will yield a much better picture with no interference from any local channels. You have to select a "video in" with your TV menu instead of using channel 3 (for example).
    Some newer satellite receivers don't have a coax output so you may have to use HDMI or component connections.
    If you have a video distribution box that will have to be taken into account.
  • wa8yxm's avatar
    wa8yxm
    Has anyone used the CABLE in cable for Sat TV: YES. many
    IS there as switch or something: YES
    OK, how do we do it? (I suspect that is your real question)
    Two answers: First the "official" answer
    Somewhere in your RV is, most likely, a wall plate (I will describe the box of many buttons at the end) it has a SWITCH, a LIGHT an antenna connector (F-Connector) and a 12 volt accessory outlet (Very low current, might charge a cell phone or run a LED map light).
    Remove it from the wall. ON the back will be two wires for 12 volt (Do not disturb) and 3 coax cables.. Disturb the one in the middle, in fact disconnect it.. then using a double female (Barrel) connector extend it out to your Sat Receiver.
    IF the sat receiver has COAX OUT.. Connect that back to the center port on the back of the switch.
    Job done.
    My recommendations.
    Forget that low cost RG-59 Cable completely leave it just as it is and run brand new RG-6, you can get the bulkhead (Through wall) connectors at any RV place or you can run to a ground block (Any RV or Electronics place including the proper isle at Lowe's et-al) in a basement compartment.
    Mine is on the Brake Bell Crank Bracket under the hood.
    Box of many buttons: One of the cables on the back is marked "CABLE", Instructions are the same as with the wall plate but you disconnect THIS cable instead of the "Center" one.
  • Just run a new coax to a barrel connector in the nearest storage locker.
  • In most cases you can use the "Cable" connection for either satellite or Cable but it will require some wiring modifications. As mentioned above, some RV's are wired with splitters from the outside cable connection to the various TV's and if this the case case then you simply cannot use that connection. There are many ways to wire in a new coax with a direct connection if splitters are a problem for your setup.
  • There are a lot of different wiring configurations in RVs. Mine originally had a single coax input setup for cable. No dedicated sat input. But that coax came into a dual coax wall plate near the TV. And there was a short coax jumper cable between the two connectors on the wall plate. I could leave the jumper on if I connected to cable. Or remove the jumper and connect a short coax cable from the wall plate to my sat box for satellite. That worked fine.
    But I tired of messing with the jumper and added a new external coax connector connected to a new inside wall plate dedicated to satellite.
  • You can install a pigtail connection in the booster box to make the connection a continuous one.
  • The booster is for over the air TV stations. If the cable in is hook up to your TV you should be able to use it for your satellite.
    Good Luck
  • That would work as long as the coax run from the outside connection to the receiver did not contain any splitters. You could use a high quality A/B switch for changing between cable and satellite.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,801 PostsLatest Activity: Jul 05, 2025
