Golf_Guy's avatar
Golf_Guy
hdmi wireless transmiter and reciever
Has anyone used an HDMI wireless transmitter and receiver to get HD from main TV to bedroom TV in a class A 37'. I have been researching these on Amazon and would think this is a good solution to getting that HD signal to the bedroom without running a HDMI cable through the ceiling somehow. I read somewhere someone went through the AC vents with an HDMI cable. That's sounds very complicated.
  • Thanks for the input. I set this up today and it was easy and the picture was perfect in the bedroom. Unfortunately no sound evidently the Denton amp is not compatible to the Actiontec system from Best Buy. May try a different manufacture and see if it compatible with my amp.
  • I installed this gizmo last April and it's been working fine most every day since.
    http://www.amazon.com/gp/product/B00630WKGI/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
  • I have that set up in my coach now. I use it to get wireless HDMI on my two other TV's. It's made by Key Digital.Their web site is:
    key digital.com. It works very well.
  • Do a Google Search for HDMI over Coax. Like this.
    I have used a couple of different wireless methods and both had their weaknesses. Neither were used in an RV.
  • If you have a TV in the bedroom already, I would contact your manufacturer for a wiring diagram to see where the coax to the bedroom RV is routed. You may find all of the coax runs start at the same place and you can just use that coax by unhooking from the antenna feed or what ever it is hooked to.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
