donnyB7's avatar
donnyB7
Help with MH Televisions
I need some help with the two TV's in our Winnebago MH. I have never used them before, and now that I am trying them, I am completely stumped. No matter what I try, neither will work. The main one is a 24" Sony Wega and the other is a 19" RCA. In addition to the two TV's there is a TV/VCR/TV2 switch. It has push buttons for SAT, Aux, TV Ant, VCR, & CATV for each item. There is also a small box that says Digital Stream DTV. This has coax connectors "in from Ant" and "out to TV"
If I just turn on the TV, all the channels have snow. If I turn on the DTV box, all the channels have snow except for channel 4. This channel is set on the DTV box. I have a Winegard bat wing antennae and no matter which direction it is aimed I get "Weak Signal" on channel 4.
Just to rule out bad reception, I put a flat screen from the house with electronic rabbit ears in the MH and tried a few channesl. No problem - several channels with a strong signal.
I thought about just replacing the TV's, but they must be bolted down and I am not even sure I can remove the old ones.
What am I doing wrong? How do I troubleshoot this?
Also, will a Winegard Wingman help?
Winnebago Adventurer 35A Gas
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,798 PostsLatest Activity: May 04, 2025
