philh's avatar
philh
May 26, 2021
Home base TV Antenna
Antenna is 25' above the ground. Running into difficulty getting a consistent signal to any of the 3 TVs. Long range direction VHF/UHF antenna with a preamp.
Original higher cost preamp just didn't work well at all. Replaced it with a cheap unit, and had a substantial improvement... but still run into complete channel loss or bad pixelation.
Bed is directly below the antenna, about 20' below it. One channel in particular, I get out of bed, signal is lost. Get back in bed, signal comes back. High quality, albeit too long, RG6 cables. To make it even more fun, if it's pixelating too much, I stretch my arm out perpendicular to my body, signal improves, pull my arm back signal gets worse.
Something in the park model is affecting the reception. The really odd part, that my body's position affects the antenna 20' above me.
Suggestions?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
