RVJimofOregon's avatar
Oct 30, 2014
How to use PDF file
I made a MS Publisher logo and saved it as a PDF file. I need to add it to a MS Word doct. and don't know how. Need Help.
RV Jim
  • THANKS for all the good input. I should of used search but didn't and glad as I found out about PNG files. Inside of MS Publisher found out I can change file type.
    Thanks again.
    Jim
  • The reason why PDF is not a good format for a logo is because a PDF is a document format (PDF - Portable Document Format) to be used for whole documents while a logo is simply an image which is a piece of a document. Save the logo in an image format such as png or jpg. Once you create a document (which may include your logo), save the document as a PDF so that it can be read on many different platforms.
  • PDF is not a good format for use as a logo in a Word document. Save the logo in PNG format instead. Then just drag and drop into your Word document at the cursor position.
  • wa8yxm's avatar
    wa8yxm
    Google PDF to WORD there are converters
    Or go to giveawayoftheday dot com
    http://giveawayoftheday.com/
    From time to time they offer PDF converters for free.
  • For a clean look. Open up your .pub in Publisher, save it as an image file . . . perhaps a .png for a transparent background and then insert the .png into Word.
  • Use the clipping tool. Open the pdf. Use clipping tool to grab your logo and the save that as a jpg file. From there you can insert into word.
