CT_WANDERER's avatar
CT_WANDERER
I-Phone Sat Finding App
Need help? What is a good app for finding Sat? I am using Direct standard sats. Did not have luck with the search. Thanks Gary
  • Boy I thought these Apps were great to get. You guys have me wondering now. I may stay with my swinging the dish back and forth. I usually find the sat in just a few minutes that way. The only thing is if there are trees in the way. That is what I was looking for. Something that would let me know if the trees are in the way. Thanks everyone.
  • Ivylog wrote:
    When I move my phone left/right the sats move about half as much as I move.
    x2
    Same with SatelliteAR. I rely on my magnetic compass almost all the time.
  • Ivylog's avatar
    Ivylog
    I have SAtoolz for Direct and have found it to be off by as much as 30 degrees azimuth. When I move my phone left/right the sats move about half as much as I move. By taking several readings I can narrow down the sat's location. Elevation seems to be accurate. It has not replaced my good compass plus you have to have good cell service for it to work. I just compared it to my locked on 101 sat and it's off by about 15 degrees. Still worth the $5.
  • SatelliteAR. The elevation and azimuth given by the receiver is usually enough.
  • I use the SAtoolz for directv and I use it to avoid trees before I set up the dish.
  • SAToolz has apps for direct and dish 4.99 is the cost . The dish one is what I have and it works well to find the sat position in the sky.
  • Well the app used to be called Dish Pointer AR. All I can find now is their "Pro" version Dish Pointer AR Pro There used to be a much cheaper version. It might be still there for the iPhone but I'm looking from an iPad
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
