- gkainzExplorerI plugged in a Bad Elf gps on my non-cellular iPad mini for an aviation GPS nav unit. Worked just fine.
- 1492ModeratorYou never mentioned what version of the iPad you acquired?
A more straightforward solution may be to just sell your present iPad on Ebay, and get a used WiFi/Cellular model? A list of iPads compatible with latest iPadOS is available here. Some available under $200.
If you're using it primarily as GPS, and don't need the current features supported in the most recent iPadOS, then a few are available for less than $100. that support version 12. Check the GPS app you want to use, though many popular ones still support iOS/iPadOS 12 and up. - dryflyExplorer
fyrflie wrote:
dryfly wrote:
I recently got a wifi only (non-cellular) iPad. Is there a way to tether the iPad to an iPhone to enable using it as a GPS device?
Just found this after I posted my response.
“AirLocation is an iOS app that sends GPS data from your iPhone to your Wi-Fi-only iPad. To use it, you activate the Personal Hotspot on the iPhone, connect the iPad to the hotspot and run the app on both devices. Now you can use proper, accurate GPS data to track yourself on the iPad's large screen.”
https://www.wired.com/2011/04/airlocation-sends-gps-data-from-iphone-to-ipad/
I couldn’t find the actual app anywhere but it did lead me to numerous other posts both on the internet and YouTube about how to accomplish what your trying to do.
Hope this helps.
That sounds like the solution, but as you say the app is nowhere to be found. I'm surprised there are not more apps like that out there. I'll do some more searching and look for the posts you mention. Thanks. - fyrflieExplorer III
Hope this helps. - fyrflieExplorer IIII have a slightly different setup than what you are asking. I use a Garmin GPS receiver and connect it to my iPad via Bluetooth. Then use any navigation program you want. I get the large, easy to read screen and great useable features without relying on cell service.
I have read that an iPad with cell capability has the gps chip built in. And you do not have to pay for an extra phone number.
But to answer your question, I have not tried to connect my iPhone to my iPad for navigation. Only for hotspot use while camping.
Good luck. Jackathan wrote:
Does the iPone actually use GPS satellite signals direct? I thought phones used the cell tower position to geolocate the phone.
Wifi only iPads do not contain the GPS hardware to allow them to act as a standalone GPS. The OP is wanting to know if the iPhone can somehow share it's GPS info with the iPad. I don't believe simply using the iPhone as a hotspot will work for that. It would be easy to test, though.- wa8yxmExplorer IIIThe necessary Adapter to plug in a USB device like the Microsoft Dongle I have
I'd offer you the MIcrosoft dongle free if I knew where it is.
The Garmin GPS-18X with USB plug hower is likely much better "Dongle" I'm not getting rid of that one. NO way.. (I hope to install it in a week or 2) - dryflyExplorer
wa8yxm wrote:
I do not know if the I-pad can read the phone's GPS however
Can you get a GPS Dongle for the I-Pad. most of them are designed to plug into USB-2 or 3 but you might be able to find one for the pad. This will be WIRED however (plugs in) I have one for a radio I use that I've yet to install (Need better weather and a few parts) Once that's done my radio will know where it is all the time... (some of them do now but this is the one in my car so it moves)
If the pad has a standard USB port look at the Garmin GPS-18X The one I have does NOT have a USB connector but they make it with.
I am not that familiar with the iPad but I don't think the port on the iPad is a standard USB 2 or 3 port. Maybe someone will correct me if I'm wrong. I bet if it were possible there would be lots of info out there, and of yet I have found none.
I did a quick look at the Garmin 18X and it appears it is for interfacing with a computer. Since I have other GPS devices to rely on, I'm not that interested in spending a lot of time or money, but just wondered if the phone and pad might work together. It's looking like it's a no go. - wa8yxmExplorer IIII do not know if the I-pad can read the phone's GPS however
If the pad has a standard USB port look at the Garmin GPS-18X The one I have does NOT have a USB connector but they make it with. - opnspacesNavigator IIThe only way I know is to swipe up on the bottom (down from the top on some versions) of your iphone to find the screen where you can turn on airplane mode or adjust the volume. On that screen click on the mirroring button and see if your ipad shows up. It won't be perfect, but it will be larger than the iphone screen.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
