IPAD
M_GO_BLUE1
Our Ipad continually freezes up on us and is frustrating...only way to get it to unfreeze is to turn off and on and sometimes that doesn't even work...
Any suggestions or advice on what I can d o to stop it from freeling up?
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
11 REPLIES 11
JaBob
Take your IPad to an Apple Store. Why play around.
Bob
ReadyToGo
Smiley.
Are you guys sure the OP isnt posting about a windows computer in error?
Everyonr knows an Apple product is perfect and you never have to reboot or reinstall the OS.
Mountain_Mama
Also, have you ever cleared out all your browsing history & cookies in Safari?
2003 Holiday Rambler Alumascape 34RLT
wildtoad
Before you completely reset your device, if have not already done so, try closing out all your apps. This is done by double clicking the home button, then sliding all the apps towards the top. Then do what Mona4 suggested. I have found that doing this on a regular basis keeps things running quite nicely.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
Mona4
Try the following: hold the home key and the start-up button down at the same time until your apple is seen on on your device. This is similar to rebooting your computer system. We usually do this to IPads that freeze. Resetting your iPad is your last option. If you need reset your iPad make sure you back up your system to another computer or to the cloud.
Winnebago_Bob
Full restore if nothing else works.
2017 Winnebago Aspect 27K
OutdoorPhotogra
Mine was doing that. It was almost full. Deleted apps I don't use, etc and solved the problem.
2008 Rockwood Signature Ultralite 5th Wheel
F-250 6.2 Gasser
Former PUP camper (Rockwood Popup Freedom 1980)
2oldman
Google: iPad freezes
SCVJeff
I have seen a lot more keyboard freezes with iOS8 that anything previous. This issue is really better in an Apple form where you will find thousands of users.
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
M_GO_BLUE1
If I did the reset do I choose reset all settings OR erase all settings and content?
Toddupton
Do a full reset wipe all data and see if that helps.
