โJan-30-2019 05:01 PM
โFeb-03-2019 06:21 PM
Fizz wrote:
Start with a simple search like "building a music library"
If you can find a forum on it go for it.
โJan-31-2019 02:13 PM
โJan-30-2019 06:52 PM
STBRetired wrote:
From the iTunes menu, choose "file" and then "Add to library". That should open a window where you can select folders to add
โJan-30-2019 06:50 PM
โJan-30-2019 06:33 PM
โJan-30-2019 06:13 PM
T18skyguy wrote:
Perhaps try to select all the folders by holding down the shift key, select the first folder, then continue to hold the shift key select the last folder, and then all the folders should auto select. If it doesnt work on the folders it would probably work on all the files in each folder.Then right click send to or you may be able to drag and drop them all. One of the main ways Apple keeps you locked in their ecosystem is to hold your music hostage. They been doing that for years.
โJan-30-2019 05:55 PM
โJan-30-2019 05:20 PM
Fizz wrote:
I can't help you but I suggest you stay away from iTunes. Just when you think you have it figured out the change things up. It is the most frustrating software I ever played with.
โJan-30-2019 05:14 PM
