Bill_S_1
Apr 14, 2015Explorer
Well I finally got it set up as a WAP switch. What I did different was after setting security key, and SSID, I went in and changed the D-Link defaul router address to an address within the range of the Verizon router addresses, then after I did that, I entered that address in the browser, and was able to log back in to the D-Link. I then set DHCP to OFF.
So now it works as I want it to, and there are no conflicts (or shouldn't be). Did a speakeasy test of Verizon, with CAT5e cable connected to PC. 15-16mb/sec DL, and about the same for UL. Tested through the D-Link WiFi, and it drops to less than 9-10mb, but that should be enough. Verizon is on ch 11, and I put D-Link on ch 1, so they are separated as far as can be, freq-wise, and the routers are physically quite a distance apart.
If I need more through-put on the D-Link, then I'll look for a Linksys router, and do it all over again.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
