Here is the deal: a couple years ago, I switched from directv to dish network. I was only using a single lmb receiver with directv. I had no problems what so ever. Now, I pourchased a dish 1000.2 around the same time that I switched providers. I'm finally getting around to try out the new hd dish.
Okay so, I set the skew, elevation and plumbed the tripod. Next, I connected the rg6 cable to the middle lmb. Then, I mounted the dish and used a compass to find the azimuth. I connected the rg6 to a vip211k receiver; and then the 211k to a Hdtv with a hdmi cable. I went into dish pointer on the receiver and could not get a signal. I tried different satellites and ports on the 1000.2 without any prevail.
So, after a few hours and beers later, I called it quits. I tried again a few days later and came to the conclusion that the 1000.2 didn't have a clear line of view to the sky. I decided to order a 1000.4 lmb and use it on the dish that came with the 1000.2 (and this might have something to do with my next problem), I will explain.
Okay, after receiving the 1000.4, I set it up the same way as described above-and to my surprise I picked up satellite 61.5. I had about a 41 percent signal and all channels seem to be working. However, I could not get 72 or 77 and I even tried connecting two receivers and tvs at the same time. I did get 72 to come in but it said wrong satellite and would show a complete signal lost when trying to view programs.
Now, could this be because the skew is off? I read this morning that the dish from a 1000.2 and 1000.4 are different. They are opposite which means my dish would have been tilted the opposite way. Any help is appreciated. Thanks.
2014 Open Range LT308BHS
1999 F250 Diesel
