- NaioExplorer IIHello,everyone :-)
My location eliminated 3G last fall. But just in the last few weeks my two mobleys have been dropping internet connection more often than usual.
Does this mean it's time for me to finally get a hotspot? Which one? Or is it too late?
Do I need to get the unlock codes from AT&T? Is it possible to do that through some website or something and not by using the phone?
Appreciate any advice! - cooperwlExplorerHas anyone had success getting the PUK codes for a Mobley SIM lately?
- DtankExplorer
1492 wrote:
T-Mobile 5G router is a Nokia brand using the newest WiFi 6, 2-Ethernet ports, and a phone port. You can set SSID, passwords, admin credentials, manage connections, and monitor tower stats from smartphone app.
Just remember T-Mobile home internet is not for travel. It's based on a fixed address.
Note on - "check for availability":
A T-Mobile store can check for you if the *home* internet is available in your area based on your zip code.
If it is not - they will put you on an e-mail notification list for *when* it becomes available.
In my So. CA zip code it is not yet available. No clue if the "roll out" is based on geography, population - or both.
:W - 1492Moderator
Just remember T-Mobile home internet is not for travel. It's based on a fixed address. - TenOCNomad
1492 wrote:
I picked up my free 4G/5G T-Mobile router at a company retail store, though have been told that limited stores have them in stock at this time. So better to call ahead to check availability if that's where you want to get one.
More information on the free 4G/5G router please. Model number??? - 1492Moderator
MrWizard wrote:
Three days ago I signed up for & ordered the T-mobile wireless home internet, unlimited data no throttling...
My T-Mobile home internet has been consistently 5G, though speeds can vary. I'm thinking due to periods of high tower usage. Amazing considering the 5G map shows that the closest tower is a couple of miles away. Though likely intermediate antennas located nearby my location but not indicated? :h Still easily fast enough to stream 4K video at the slowest speeds I've seen. Haven't personally done so yet.
Speed test just now with T-Mobile router signal strength indicated as 3/5 bars (Good): - Dutch_12078Explorer III've had the Netgear 815S that uses my Mobley SIM set to "4G and LTE only" since the first of the year and haven't had any connection problems even when on busy towers where speeds noticeably slowed down. My only concern with the 3G drop will be whether AT&T could use it as an opportunity to drop the Connected Car plan entirely. It does appear that AT&T is using the same Connected Car plan for the current "Harman Spark" OBDII device they used for the Mobley, so I expect our Mobley devices/SIMs will continue to work.
- NamMedevac_70Explorer IIThanks for that important to me information Mr. Wizard. I will follow your advice before cutoff date. Cheers to you.
- MrWizardModeratorI downloaded the AT&T supported phone list
Page 7, the last page , lists the hotspot devices that will be supported, the ZTE Mobley model VM6200
Is not on the list
The unite explore AC851S aka Netgear 8155 for AT&T
Is on that list, this is the device my Mobley SIM is in,
The device/Hotspot I'm connected to right now
It seems the best option to keep a Mobley account going,
Is to get puc (SIM unlock code) from AT&T , unlock the sim and move the SIM to a supported Hotspot deviceClick For Full-Size Image.
To the OP
Thanks for calling attention to this
Users now have have time to replace the device or wait until Feb 2022 and drop the Mobley service account
AT&T does have a 100gig hotspot data account for $55, that would fill the need for many users - MrWizardModerator
theoldwizard1 wrote:
If I am going to have a wireless home internet connection I want a device that has 1 preferably 2 connectors for external antennas.
My netgear hotspot has (2) external antenna ports,
And I have the MIMO antenna for it
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
