planned GPS outage on the west coast
agesilaus
THe Navy is up to something--secret: POPMech
May not affect you too much on the ground unless you are near the Naval Weapons Station in the SoCal desert.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
31 REPLIES 31
harold1946
SCVJeff wrote:
Us out West wrote:
harold1946 wrote:
Are there that many RVrs that travel at 40,000 feet or even 50
Exactly....not an RV topic but whatever. :S
I would think both of you desert guys would have some idea how flat the desert is, and GPS at 1.5GHz is line of sight. This test is in East Edwards which, if a true jammer, will wipe out anything on the 58 and 395. So I think that qualifies.
Anyone that needs a GPS within the test area radius on the 58 or 395 probably should not be driving. Even Ray Charles could have driven through that area and not gotten lost.
Has anyone ever gotten lost in the Isenhower tunnel when they lost GPS signal? :B
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
JaxDad
Tvov wrote:
I'm curious how you can "block" GPS only in the air, but not on the ground? Wouldn't anything blocking it in the air, prevent the signal from getting to the ground?
It's not just in the air, but because radio signals are easily blocked by things like trees or buildings it affects a far larger area in the air than it does on the ground.
nomad_297
For years, whenever I get to within a few miles of Andrews AFB in Maryland and a few miles of the White House, my GPS starts to lose satellite connections. Some days are worse than others.
Bruce
Tvov
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
SCVJeff
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
SCVJeff
Oh great !
So I got a brand bakers dozen box of missles and a couple of rusted VW's in the desert, and now you tell me I can't aim em' ?
Jeff - WA6EQU
Us_out_West
Our Trip Journal
2012 Jayco Pinnacle (View)
36 KitchenPantryTripleSlide
MorRyde pin box and suspension, Curt Q24, Dual Pane windows, Auto Levelers, 2 AC's,and more.
2009 Silverado 3500HD 4X4 (View)
CC, Dura-Max 6.6/Allison,LB ,DRW,Amer. Tank 65 gal. Aux Fuel
Dick_A
Moved from General RV'ing forum.
2009 Tiffin 43QBP Allegro Bus
RoadMaster Sterling Tow Bar
US Gear UTB
Ford Explorer Sport Toad
WA7MXP
"Pisqually" the attack kitty :B
CavemanCharlie
Not that I know of,,, but, that would be COOl !! :C
harold1946
Harold and Linda
W-22 Workhorse 8.1L
Explorer Sport toad
Gene_Ginny
agesilaus wrote:
... You have to wonder why they don't try it out over Johnson Atoll or some other isolated spot. ...
Too hard to move the technology from China Lake. More info here.
China Lake, which tests weapons and avionics for tactical aircraft, encompasses 1.1 million acres, which makes it larger than Rhode Island.
Should only be a problem if your RV or car is 50 feet off the ground.
The testing centered at Naval Air Warfare Center Weapons Division based in China Lake, Calif., could affect aircraft at least 50 feet off the ground within hundreds of miles of the base to as high as 40,000 feet above sea level nearly 550 miles away.
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
NYCgrrl
gbopp wrote:
I think the article said it will only be disabled for aircraft above 40,000 feet.
If they turned it off in a populated area, some people couldn't find their way to or from work.
Yes that's what the linked article said right at the beginning:
"Starting today and continuing intermittently until the 30th of June, the Navy is doing something that will knock out GPS signals in the Mojave Desert. They won't say what that something is, though.
The FAA has issued a warning to all "aircraft that rely on GPS," (your bi-plane is fine) that once someone gets around 40,000 feet in the air on the 7th, 9th, 21st, 23rd, 28th, and 30th of June, between 9:30am and 3:30pm, their GPS will not work."
Bucky_Badger
kalynzoo wrote:
So how many people will get lost? We depend on GPS now for so many daily functions, like tracking deliveries, tracking employee vehicles, tracking just about everything. Call for ERS and they track your phone location by GPS. I just hope the DOD knows what it is doing. ๐Ÿ™‚
errrr, the sky is NOT falling
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
gbopp
kalynzoo
