Sensar 4 antenna problems
bennefim
Replaced old sensar 2 antenna with new sensar 4 with wingman. Getting 12 volts to new antenna head , but no signal. Any suggestion other than replace.
Anyone know wArranty on winguard antennas.
Doug
11 REPLIES 11
wa8yxm
MOst people do not know this but there is a MINIMUM Radius for a coax.. And it can be as high as six inches for some types.. Or as little as an inch or two for others. And before you ask. NO I do not know the minimum radius for the brand of RG-59 You have
bennefim
Culprit was two f connectors behind the antenna mount in ceiling. The connector problem was too much stress on the coax caused by sharp turn in wiring. Replaced two connectors and barrel fitting and made more space for coax to make gradual turn up to antenna. Working real good. So far so good.
Thanks for the help, Doug
Tom_M1
Here's a link to an article by Chris Bryant that may help:
Tune up your TV antenna
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
bennefim
Will give it a good second check and report back. Thanks.
Doug
wa8yxm
No getting voltage means SOME of the connectors are good.
What I have seen is that the center wire needs to go farther into some connectors and if it is cut a bit short. Well contact is NOT made.
bennefim
If you get voltage,wouldnโ€™t that mean coax connections are good?
The old sensar quit working after about 10 years. New sensar 4 worked great for about two months, then quit also......power but no signal.
I will try temporary new coax as suggested to see if any difference.
Doug
Tom_M1
From the manual for the Sensar IV:
Winegard Company warrants this product against defects in materials or workmanship for a period of two (2) years from the date of original purchase. During year one (1) of such warranty, Winegard Company will also pay authorized labor costs to an authorized Winegard dealer to repair or replace defective products. No warranty claim will be honored unless at the time the claim is made, Customer presents proof of purchase to an authorized Winegard dealer (to locate the nearest authorized Winegard dealer, contact Winegard Company, 3000 Kirkwood Street, Burlington, Iowa 52601, Telephone 800-288-8094 or visit www.winegard.com). Customer must provide proof of purchase with a dated sales receipt for the Winegard product to verify the product is under warranty. If the date of purchase cannot be verified, the warranty period shall be considered to begin thirty (30) days after the date of manufacture.
Tom
2005 Born Free 24RB
Minneapolis, MN
wa8yxm
Suspect #1 is the coax end (Connector) if the center wire is cut a bit...short.. it may not be making contact with the center pin in the antenna.
Suspect #2 is the other end of the "Above the roof" coax where it connects to the longer run at or in the roof.
To test
Get a length of coax RG-6 or 59 don't matter. Long enough to reach from teh power source (Box of many buttons, wall plate. Sensar Pro) to the roof top antenna via window or door. Run a direct line. if it works. Then clearly a coax issue.
D_E_Bishop
I'm not an expert but if all you did was disconnect one and hook up the other, you shouldn't have to do anything else.
This brings to mind, what has happened to SCV Jeff? I haven't seen any posts lately, tried a search and I get an error message.
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
wildtoad
Did you replace just the head or did you change anything inside? Since you are getting 12v at the head, the power supply is working. Have you done a new channel scan on your TV(s)?
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
rk911
Doug
sounds like the antenna cable is not connected. double check. are you in range of tv station transmitters? was old winegard receiving anything?
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
