You are probably going to end like the rest of us doing this. Once you add the INVERTER just for one item you will quickly discover "Hey this is nice" and then start wishing you have enough Inverter power to run other 120VAC items.
I started out with a 150WATT model, then went to a 300Watt model, and finally ended with a 600Watt model.
My INVERTER is the AIMS PSW 600WATT model purchased from AMAZON for $149 I think it was five years ago...
I routed two 120VAC Extension cords with multi-head 120VAC receptacles on the end and permanently mounted them to the back of the Home Entertainment Ceneter location and the Bedroom night table location.
These extensions cords are hidden from view going behind cabinets and inside wire management cable protector from LOWES with only the multi-tap 120VAC receptacle showing on the back on the table tops. These two 120VAC extension cords plug into the front panel of the 600WATT Inverter.
Being PURE SINE WAVE I don't to worry about what I can or cannot plug into it. This works good with other unknowing folks in my trailer. All they will see is a 120VAC receptacle and who knows what they might plug into it. made good sense to me to just go with the PURE SINE WAVE model Inverter.
My low wattage MSW Inverter didnt go to waste as I use it to power up my outside lights when camping off the power grid...
Roy ken
