Mikesr wrote:
Some of the specific questions and concerns we have is with peripheral devices like printers, external hard drives and data files stored on flash drives and portable HDDโs.
Will our PC data files (i.e. word documents and photos) work on an iMac?
Your iMac should have no trouble accessing these devices. For example, image, movie, and music files should open and run seamlessly. For Microsoft Office files (Word, Excel, etc), I use the free, open source
Apache Open Office -- it slices, it dices . . . and it's free.
As someone else mentioned, I'd suggest buying
Parallels for Mac software. I run Windows XP and Windows 7 which allows me to run just about anything.
Likewise with printers, but you may have to get the applicable software drivers. Do your homework and check if they are available.
Mikesr wrote:
We understand the iMac will be a chunk of change and we plan to spec it for RAM and processing speed to be higher then our current needs.
Great minds think alike . . . I'm doing the same thing -- and, yes, the iMac Pro is out of my price range (starts at $5K! Yikes!)
However, I would suggest a 27" 2017 5K display iMac, preferably with at least 16 GB of memory and at least a 2 TB internal hard drive.
Memory Upgrades are easy and inexpensive, but upgrading iMac hard drives is not easy --
it involves 34 steps. You can get up to a 3TB fusion hard drive pre-installed which is what I'll probably do.
Anyway, there are not a lot of
used 2017 iMacs out there, so I'd recommend either the
Apple Store or the
Apple Refurbished Store where good deals can be had.
Finally, iMacs (and other Macs) come with Time Machine automatic backup software which I recommend you use. However, you'll have to re-purpose any hard drive you have laying around or shell out for a new one. I recommend
Two, 4 TB, USB 3 hard drives that you could run as RAID 1 . . . and Macs also have build-in RAID software.
2004 - 2010 Part Timer (35โ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41โ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31โ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.comDISH TV for RVs
