lawrosa
Mar 09, 2018Explorer
Ive used this ecoworthy 20 amp model MPPT with a 280w - 38 volt panel.
IMO start with this. Its cheap and works. Accepts up to 50 volts and 300 watts of solar.
IMO upgrade to a larger panel and use this. It will serve you well for a few years.
http://www.eco-worthy.com/catalog/worthy-mppt-solar-charge-controller-12v24v-p-182.html
89 bucks on amazon...
https://www.amazon.com/Solar-Charge-Controller-Regulator-solar/dp/B00FF1KGT4
A panel like this is a nice start.. Hook both panels in series to get close to max the voltage of controller. That controller will take the extra volts and turn them into amps..
http://www.eco-worthy.com/catalog/worthy-120w-foldable-polycrystalline-solar-suitcase-p-375.html
https://www.amazon.com/ECO-WORTHY-Portable-Polycrystalline-Foldable-Suitcase/dp/B00MGLIIQO
If you have the money get the 200 watt case
http://www.eco-worthy.com/catalog/worthy-200w-foldable-polycrystalline-solar-suitcase-p-499.html
This shows how mppt can turn 5.7 amps from my two panels @ 59 volts to 28 amps charging @ 12.7 volts. Although this is a 40 amp mppt and 560 watts of solar.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
