TPMS
rfsod48
When using TPMS do you use flow thru monitor or remove monitor to adjust pressure?
Roland,Linda and Matt Schwarz, LuLu, MoMo and Chewy
2005 Fleetwood Bounder 38N Catipillar C7
2015 Jeep Cherokee Latitude 4wd Drive II
Go Bucks!
7 REPLIES 7
Ron3rd
cochise49 wrote:
I have to remove my sensors. Not an issue after you get the hang of using the "special tool."
That's what I do with my TST 507 system, very quick and simple. The only downside I've heard with the flow through sensors is they are slower to fill, but that would not be a deal breaker for me. I don't think they had the flow throughs when I bought my TST.
Equilizer Hitch
Honda EU2000
rfsod48
Tank you all for your help??
Go Bucks!
fj12ryder
I have the flow-through sensors and if I had to do it over I would give them a big ol' pass. It takes forever to add any air to the tires because of the restrictive nature of the sensors. So if I have to add more than a couple of psi, I end up taking the sensors off anyway.
Howard and Peggy
"Don't Panic"
edatlanta
I remove the sensors (non-flow through) when I arrive at a new destination. Air pressure activates the transmitters and I save battery life this way.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
dalenoel
I have to remove the whole sensor. Not a problem and love the system.
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
cochise49
Bev& Keith
2014 Winnebago Adventurer 38Q
2013 Honda CRV, Roadmaster Falcon AT, Invisibrake
TucsonJim
I have the flow through sensors, but I found it's easier to unscrew the whole sensor to make an adjustment versus the valve cap. But that's just the way my wheels and stems are set up. On my last rig, it was easier to remove the cap instead of the sensor.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
