ruralgold
May 01, 2013Explorer
Trouble replacing rear view camera monitor - any ideas?
I've got a 2004 Newmar Kountry Star with a ADTH monitor 12v, B&W. It's small and difficult to see so I decided to update the system. I purchased a Pyle Audio rear view camera(color) and 7" color monitor. The cable that came with the package is long enough for a car, but not for the RV. So I decided to replace the monitor first, keep using the B&W camera and replace the camera later.
I pull off the monitor and discover that the cable from the monitor to the camera is S-Video, 4 pin. The new monitor uses an RCA video connector. I hook up the power connectors to the new monitor, everything looks good. I figure I'll get an adapter for the S-video to RCA video and use the same cable and camera for now.
Okay, a couple of days later I get the adapter. I put the adapter in place, turn on the ignition, the monitor lights up, no signal. Switch to the other video input, still no signal. Try this several times, just for grins. Still no signal.
I'm thinking that I've screwed up the cable somehow, so just to make sure, I put the original B&W monitor back in place. Everything works fine, picture looks like it did.
My question is, can I use the S-video cable with the adapter, and if so, how?
Any help would be appreciated on this. Oh yeah, this is my first post, but long time reader. Thanks
Rory Martin
Rory Martin
