- hbradyExplorerI've used Anonymizer for years, 45 day free trial with no CC required, then it's $7 a month. www.anonymizer.com
- lynndiwagonExplorerIt's a long story, and took me a long time to get. First you must have your account carried under a business. The APN name for ATT is "i2gold." I use the hotspot to access IP cameras and the static IP address follows me nationwide. I'm using an ATT Unite hotspot. Costs an additional 3.00 dollars a month. Google i2gold.....
It's worth every penny. - MrWizardModeratori'm confused
how can a mobile hotspot have a static IP address ? - lynndiwagonExplorerI've used VPN Unlimited for the past several months and I'm completely satisfied. If you look around you can get a real good deal for a 3 year subscription. You can use it on 5 devices. I needed it so that I could change my IP and access my hotspot, which has a static IP. AT&T doesn't allow mobile to mobile data connections so I go through a VPN Unlimited server first to change my IP. Look around and you can get a really good deal for a 3 year contract. It doesn't slow down my internet connection any at all that I can tell.
- hawkeye-08Explorer IIITorGuard
- ssgwsmithExplorerRecently critical risks have been revealed with the use of VPN and IPSEC.
Be sure that your key length is at least 4096 bits long or your data may be vulnerable.
If you have specific questions I can assist.
waltersmith@affinitycyber.com - jorazExplorerI use OpenVPN. Many domestic and foreign servers and always adding more. $9.95 per month - month to month.
jor - mlts22ExplorerI use VyprVPN, just because they are based out of Austin, and support the local Linux community.
The main reason for this is simple -- there are a lot of attacks someone running a wireless access point can do, and by running a VPN, all they see is just an encrypted pipe from your computer or device to the VPN provider. - KlickITlikeMeExplorertry this side
It helped me a lot when I was travelling and needed a VPN
www.anywhere.fm - mohammadhill459ExplorerAre you going to set-up a VPN in Mexico? If so, you can find many different VPN in the internet if you will be patient enough. I found a comprehensive list of best VPN for Mexico in BestVPNServiceMag.There are many reasons why people opt for a VPN but the most important reason is that it helps you conceal your identity.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
