spider_man's avatar
spider_man
VW Bay Window 1978 cord/converter
Hello,
looking for a cord to connect my 1978 Bay Window VW ti european power.
What do I need? A cord including converter from 220V would be great.
In any case: what is the official name or code for the male plug I need to connect to my externalconnection on the VW as shown in the picture?
THX and bye!
Andrew
  • 300 Watts seems a little low.. Figure out the total wattage required to run everything in the rv and add a little extra buffer.
    The receptacle on your rv is a recessed 120v polarized grounded receptacle. Uses a standard US 120v extension cord.
    Had a similar problem many years ago. I bought a 3000 watt 220-240 volt to 110-120 volt transformer. I mounted it in the camper and converted the US receptacle to euro. std. Don't remember the type.
    C of F, That was a long time ago and I have forgotten. I do remember the Mark was .25 USD
    This way you will be German on the outside, US on the inside.
    Mine was a cheap, temporary solution. easy to convert back.
  • this will work
    https://www.110220volts.com/500-watt.html
    probably need to build a case for it.
    As for the cord any good 12 gauge outdoor cord will do
    https://www.amazon.com/Iron-Forge-Cable-Extension-Grounded/dp/B019P9ZGGO/ref=sr_1_3?s=lamps-light&ie=UTF8&qid=1473946542&sr=1-3&refinements=p_n_feature_keywords_browse-bin%3A4459667011
