mikestock wrote:
Tom_M wrote:
The OP claims he has "double insulated". I assume he meant double shielded. The stripper should expose 1/4 inch of center conductor and strip a 1/4 inch of the outer jacket which leaves one foil shield and one braided shield. Fan the braid back so that it folds over the outer jacket. Do a search on YouTube for videos on how to attach F type compression connectors if you are still having problems.
He (I) have a single layer of braid over, what looks like, a layer of aluminum foil.  I guess that's double shielded.  When I use my little stripper tool it looks beautiful. Then the battle begins. Once I get the stinger exposed beyond the threaded part the battle is over. The compressing part is a snap.
Make sure the diameter of the center of the connector is the correct size. That center should be just large enough to slide over the wire center insulation, if center is too big it will make it nearly impossible to push under the outside jacket.
If too small you would have to trim down the center insulation and be nearly impossible to fit under the outside jacket.
Something else to try, warm up the coax with a hair drier, not so hot to burn yourself, you only want to get just above room temp.. Some jackets get pretty stiff when cold making connector installation near impossible..
The center of the connector must go under the jacket so it displaces the shielding and stretches outside jacket.
Have done a lot of cold weather connector installations back in the late 80s with big C band dishes.. Connectors don't go on very easy at 32F or below had to warm up the coax to make the job easier..
Something else to consider, All in one coax strippers tend to strip back a bit short as far as how much center conductor comes out of the connector when done.
Move your stripper back a 1/4" on the wire and strip off more than you need. This allows you to have much more center conductor protrude when connector is fully installed. Once satisfied and crimped, you cut some of the extra unneeded length off at an slight angle. This should allow about 1/8" to stick out of the connector when finished and makes insertion of connector much easier.
I have a couple of those strippers around, I don't use them, I just use a pocket knife and eyeball it, works better for me.
