coolmom42
Jun 12, 2017Explorer II
1) connect to the router with Ethernet cable, and go to speedtest.com and check the speed directly at the router. That may be the problem. You may need a service upgrade.
2) update the firmware on the router.
3) if those don't work, get a new router.
4) run a cable directly from your router around the house. Yes, you can get CAT5 cable that long. Find a local electronics shop to make up the ends for you. Use some Command brand hooks to secure the cable for temporary use, or tuck it under some trim. Just keep it up out of the way of lawnmowers and weedeaters.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
