old_guy's avatar
old_guy
windows 10
Ever since windows 10 came out my computer goes to sleep if I don't move the mouse every few seconds. I have gone into setting and put it on every setting I can find. apparently windows doesn't recognise "never as never" it just gets worse. I can not watch a youtube video on Rving without it going to sleep. any suggestions without shooting the monitor? I have called microsoft and they took over the computer and redid some setting but still did not help. so that is not an option any more
  • Settings, Power & Sleep
    On the right, Additional power settings
    Change plan settings
    Change advanced power settings
    This will get you to the advanced power settings where you can most likely fix your problem. My wife's laptop was doing the same and that was how I fixed it. Why you have to jump through hoops to really change settings is beyond me. I know no matter what you do with the basic settings it won't keep it from turning off the monitor or going to sleep. Hope this helps.
  • Assuming the above suggestion doesn’t work, you might have better luck asking on a Windows 10 Forum. Be sure to list what has been attempted thus far.
  • Go to "Settings" then:
    Power & Sleep:
    On Battery power,turn off after - Never
    When plugged in, turn off after - Never
    On battery power, PC goes to sleep - Never
    When plugged in, PC goes to sleep - Never
    Battery:
    Turn battery saver on automatically if my battery reaches -- Use the slider to set your percent. I keep mine on 20%.
    Reboot your computer. Turn it off, pull the electric plug and remove the battery if a lap top. Put it all back together after 10 seconds, and power back up.
  • Perhaps there's someone more attuned to fixing this than anybody from Microsoft, but that's hard to imagine.
  • Mortimer Brewster wrote:
    Assuming that your mouse is plugged into a USB port, it might be that the OS is shutting off the USB ports to try and save energy. Try this.
    well that didn't work either, it still went to sleep after 20 seconds.
  • Assuming that your mouse is plugged into a USB port, it might be that the OS is shutting off the USB ports to try and save energy. Try this.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
