- dodge_guyExplorer IIIt should be in the Gem (generic electronic module) basically a computer. The flasher is built into the module and is not replaceable.
- Harvey51ExplorerOur 2004 E350 has turn signal lights and emergency flashers flashed by a cylinder the size of half a roll of quarters that is more or less loose on the end of a foot of wires. When I first found it, it was kind of hanging on the right side of the steering column under the dash. No problem getting a replacement electronic one that is the same size but clear plastic.
- richardwiseExplorerHave you looked in the fuse box? Check under dash, left side. May be in fuse box or near it.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
