rperry450
Aug 26, 2016Explorer
2008 Jayco Jay Feather Exp LGT 17c tank water system help
Hello. I'm new to RV camping. Just purchased a 2008 Jayco Jay Feather Exp LGT 17c and I cannot figure out how to use the on board water system when "dry camping" ie using the pump and on board water tank.The system works fine when connected to a hose water source. I have tested the pump and it works perfectly. The manual has no instructions for this. I am guessing there are some valves somewhere that need to be activated? Any advise would be greatly appreciated. Thank you Rob.
