4gal 2tank 125psi craftsmen compressor scfm@90 psi 2.4
barney_bugle
Is this enough to blow my 110 psi tires up (quickly) ?
I have looked at the forums, but have not seen any recommended compressors for 110 psi and above. thanks for any advice & recomendations
8 REPLIES 8
dodge_guy
Get the compressor with the higher CFM rating and a larger tank say at least 10 gallons. I do my "E" rated tires on the Excursion and trailer with a Craftsman 25 gallon 135 psi (I don`t remember the cfm, but it is lower than I would like) and it is just enough. your either going to want a much larger air tank or something with a higher cfm!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Harvey51
Compare horsepower if possible. You can get high pressure with very little power but it will be very slow. A half HP is decent. And make sure you can lift/carry it, unless you plan to leave it in one place.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
harley-dave
barney bugle wrote:
Thanks guys.im a little confused as I have seen some 150 psi with lower cfm than say a 125psi.any ideas?
the CFM rating normally applies to compressors that are powering tools. However it would effect fill time on large tires somewhat.
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
RoyB
oops entered in error... did'nt read comment close enough...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
calamus
The Cfm is cubic feet per minute it is based on the size of the cylinder . Your psi is determined by the pressure switch Which some models you can pop the cap and crank up a bit, but the tank itself is the big factor in the PSI of the compressor, as they are designed to hold only so many PSI safely.
2015 3500HD Chevy Dually Duramax, 2008 Sundance 2014 22'SSX bennington pontoon
barney_bugle
harley-dave
Good Morning
I would look at a 150 psi compressor or even a 135 psi. Those last 10-15 pounds will be pretty slow with only 15 lbs. difference between tire psi and compressor psi. Can be done though.
Dave
SKP # 121272
2oldman
Have you seen these? Compressor 110 search results
