Thermoguy
Feb 23, 2020Explorer II
Here is my experience. We purchased our RV used, mostly because we wanted to see if we would use it enough to justify the expense. We found one about 10 years old at a great price. I should have had it inspected by a professional but I have experience finding water damages in homes so I thought I knew what I was doing. A moisture meter really does not work in an RV, the walls are too thin and the meter doesn't get a good read. It is better than nothing, but not great.
The trailer we bought had a leak that I did not find. It presented itself within the first fall and good rainy season. I have had it fixed and then fixed again as these things are hard to trace to the actual source sometimes, it was coming from the roof vent for the fridge. Anyway, no water damage and after 2 years, no additional water intrusion. So, if it is fixed and dry and no damage, it will be OK. If someone finds the leak and takes care of it, then there is no reason it will come back. However the older the rig, the more likely another leak can occur. I keep mine covered all winter to help any future problems. I also check it constantly to make sure if anything else happens I fix it ASAP. So far, all good.
Happy Camping:)
Happy Camping:)
About RV Newbies
4,030 PostsLatest Activity: Mar 20, 2025
