JOERVDREAM's avatar
JOERVDREAM
cabinet making
Im one month into my first and new to me RV. Im going south to one of the LTVAs in Arizona when I retire in December. I want to make some changes like getting rid of the booth and table dining area. I am going to put a recliner and some floor cabinets in. I had planned on looking around home depot to see what I can find to work. First I thought I would ask around about the LTVAs and if their was any cabinet makers roaming around that area? Any ideas?
1 Reply
  • Home cabinetry like you find at Lowes are not subjected to weight restrictions like RV's are. Not that they wouldn't work, but a standard S&B base cabinet is probably 2x the weight of one built for an RV. Adding recliners will also probably be much heavier than the dinette you are removing. I know some folks have luck with IKEA type cabinetry as they can be found in lighter woods. Just a caution about doing all this in one concentrated area may cause a weight difference and shift the distribution in your RV.
