? CL-A TOWING A 2d VEHICLE ?
dcmac214
I don't get it. Why is it most class A coaches towing a 2d vehicle tow it on its own tires? It only increases wear & tear on the 2d vehicle. And most of them have no protection from road debris picked up by the Cl-A. If I had a Cl-A there the only way I'd tow a 2d vehicle is on a trailer. And I'd go all the way making it an enclosed trailer so I'd have my own traveling garage along with my mobile home. Color matched of course.
17 REPLIES 17
mlts22
I have seen one use of a large enclosed trailer behind an "A". One of the renaissance faire people that does "the circuit" has a type A, and a trailer. The enclosed trailer when on the road holds the husband's vehicle, a Harley trike, and the wife's vehicle, a subcompact. When at the destination, both vehicles come out, shelves are folded down, and the trailer then becomes a work office.
It works out well for them, but it does mean a lot of maintaining -- four vehicles that have to be insured and registered, sixteen tires to replace (especially with a tag axle), etc.
dcmac214
Thanks all for the insight. It's a bit different hauling m/c or ATV in toyhauler.
wbwood
Why would someone pull a TT and not just get a truck camper. That's more wheels on the ground to take care of and possible debris hitting the TT. Same concept, right?
Brian
2013 Thor Chateau 31L
cjoseph
The only positive I see with a trailer is the ability to back up the thing. Everything else is just more complicated, more hassle more weight, more negatives.
One of the reasons we wanted a Class A over a travel trailer was the quick and easy set up of an A versus all others.
I would think a car hauler trailer would require a WD hitch right off the bat. That's a big pain.
Chuck, Heidi, Jessica & Nicholas
2013 Tiffin Allegro 35QBA
tenbear
2012Coleman wrote:
Different folks, diferent strokes. Nuff said.
X2 - You can do it your way and I can do it my way. Wonderful world isn't it?
2010 Subaru Impreza Sedan
jetboater454
Same reason they strap a ladder to the ladder. :B
2011 Toyota Tundra DC Long Bed
2001 Harley Dyna Lowrider
2012Coleman
2018 RAM 3500 Big Horn CTD
beemerphile1
Parking the trailer is an issue as well as loading and unloading like others have mentioned. But also consider that you will have more total tires. Four on the towed and four on the trailer. You will still be wearing out four tires when towing but you will be buying and maintaining eight tires.
There are many reasons not to use a trailer, you haven't thought it through.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
1rickw
We have a class C and we tow our car on all four tires. It only takes about 3 minutes to hook it up and the same to unhook at a campground.
2004 Jamboree 26Q
+ great wife to travel with
:B
2012 Honda Fit towing 4 down with BrakeBuddy
Allworth
Given the expenses of owning and running a Class A, the extra cost of a toad 4-down is nil.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
wbwood
Ad when you get to the rv park, where do you park this enclosed trailer that is pulled behind a 40' motor home?
Brian
Trackrig
Unless it's a show car and needs to be enclosed, putting a car in an enclosed trailer is a pain. Have you tried it?
Originally, because we have a Ford Escape which is not towable four down, we thought of using an enclosed trailer. Try this like I did. One of our garage doors is a standard 8' door which is the same as the inside width of an enclosed trailer. Park you vehicle in the garage door so that when you open the vehicle door, it will hit the side of the garage door. I'm not fat, but there's no way I was going to get out of the Escape without climbing out through the window.
I talked to a friend at a moving company because I know they move cars inside of moving vans that are 8'6" wide. He said they have the skinniest person on the crew drive the car in with no shocks on. Then they climb out of the window, walk down the side of the car and then hope off of the back of it.
Just imagine if you're trying that and you slip, breaking a leg with your foot wedged between the steering wheel and the dash. I think the rescue crew is going to tear out the whole side of your trailer.
And to secure the vehicle, make sure you're get a door up front in the trailer so that you can enter in front of the car to tie it down. Then your're going to be down there with a flashlight hooking up the straps. A door on the side of the trailer, in the middle where the car will be won't work unless you're going to climb over the car.
Just think, you pull into a campground to just spend one night on the way to someplace else. But, oh no, you're out of tomatoes and beer. By the time you open up the trailer, unstrap the car and then restrap it down, having used my towbar that only takes two minutes, I'd be long done with dinner.
And as far as saving wear and tear on the towing a vehicle, in general you're going to do more maintenance on the trailer bearings, brakes and tires than you would on a towed vehicle. And be sure to put a hitch on the vehicle you're going to enclose so you have an easier way to move the trailer around when you get into a place where you can't turn the MH and trailer around because either lack of room or you can't see around the trailer to back it up.
If trying to get out of your vehicle while it's parked in your garage door doesn't convince you not to do it, I'll be surprised if you put up with the enclosed trailer more than one season.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Rollnhome
Oops
2008 Discovery 40X towing a Jeep Grand Cherokee
Rollnhome
I don't want the hassel of dealing with loading and unloading a trailer. Storing the trailer etc. Much easier to unhook and hook the towed. Money is not the issue it's where do you keep putting that empty box. If you have show cars and go to the shows that's a different story. This year we will travel 10k miles in about 7 months. I don't always know what the conditions will be at every stop. Much easier to travel light, just gives you many more options. IMHO
